Sealant/ adhesive selection
Northampton
Rapido & Bongone
I have discoloured sealant above the cab on my lowprofile Rapido and more importantly cracks in the joint between cab and fairing.
Now to crux of matter what actual product does anyone have experience of for this application.
My view is we are dealing with dissimilar material ie Steel and ABS, GRP, TLA and large movements may be possible so a compliant adhesive is required. (more movement than with Solar panel mounting).
my selection Soudaseal RV61 or PURAFLEX 40 any comments.
data sheet info
RV61 is used for structural bonding applications in the caravan and motorhome, car/coach building, marine, train and aerospace industries where structural elastic bonding between metal surfaces, coated surfaces and many plastics is required.
Tensile Strength 261PSI
Shore A hardness 40 ± 5
Elongation 750 %
PURAFLEX 40 is a high modulus, one component, PU sealant and adhesive
Movement capability Flexibility +- 25%
Tensile strength 220PSI
Shore A 37
Elongation 700%
Sika EBT can be used as an adhesive, sealant and a filler and is based on Sika's special moisture cured polyurethane making it perfect for both internal and external work.
Tensile strength 218PSI
Shore A hardness 40
Elongation 700%
Alternative Sikaflex®-512 Caravan
a strong elastic adhesive that bonds and seals in one operation. It is purpose-designed for
building and repairing caravans, motor homes and trailers
Tensile strength 261PSI
Shore A hardness 40
Elongation 400%
Ebt just on price.
What about 3M's 5200 that's the original industrial glue...
Probably the Stika 512 is the best option but check with Stika.
Purafkex 40 definitely not it degrades with uv and after a couple of months it gets a pink hue also not enough flexability.
Reactions: 68c
