Anybody solved the draught/Gale/rain situation when accessing boot via rear door of Ducato PVC
I am considering a homemade solution but am hoping that someone has already solved this problem.
Not had a problem as I only access it in good weather !
Once we had a draught on a cold night in Spain but I hung up the silver backed picnic blanket and that worked a treat. We have upper cupboards wrapping around so I just pushed blanket up between doors and back of cupboard and it stayed there without any fixings!
Thanks for the replies. The fix you refer to is one that we thought of too, it solves the cold bridging you can get when the meeting rails of the doors are in their metal state.
In cold weather that becomes a "cold radiator".
An easy fix which some builders identify and solve.
We had our van out for its first run in not the best of weather but
on more than one occasion we could see the benefit in having the rear doors open for view and fresh air.
I am contemplating getting perhaps a drop down fabric of some sort that has either a see through panel or perhaps a fly screen.
Just idle thinking, not top of our list.
Mine came from AutoSleeper with a colour coded fabric strip, press studded over the join in the doors, but even without it, I’ve never felt a draught in that area.
