Schaudt Lt control panel (1 Viewer)
Steve and Denise
5,294
14,092
Spalding LINCS
A Class Carthago
Since 2008
The control panel on our Hymer has gone faulty again it has lost some of the segments on the display but is also reading the wrong voltage ie 12.3v when the leisure batteries actually read 13.2v on a test meter can this have any affect on the charging of the cab battery as that was down to 11.4v.
We have an Lrm 1218 solar reg that I fitted from new and it has been no trouble for a year we have had plenty of sun but do use the cab radio a fair bit (from the cab battery)
I should add we have a replacement on order.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
I missed the cab battery bit, someone said only the other day that the solar does not charge the cab battery without battery master or CAK tanks gadget.
Steve and Denise
Steve and Denise
5,294
14,092
Spalding LINCS
A Class Carthago
Since 2008
That’s what I assumed @Lenny HB but the hab voltage fluctuates on the display by the minute I have done a check with the meter and the cab battery was only 11.6 so maybe the radio pulls that down as it has some sort of sound system in the van with a woofer etc.
Lenny HB
53,435
150,026
On the coast in West Sussex
Hymer B678 DL
A lot of the double Din units pull a silly amout of power even in standby.
Dec 31, 2010
2,635
5,822
Sunny South Shields
Frankia Platin i7900
Since 2010
Hi are you sure the radio runs of the cab battery and not the leisure batteries just a thought Steve ours runs of the leisure batteries
Jan 31, 2016
1,902
3,377
Alness, Cromarty Firth
Hymer B544 (2012)
newbie
When I fitted my LRM1218, it came with 2 leads, the instructions (in German !) stated to disconnect one lead (red if I remember correctly) then conect the second lead in line with another one. Now my van and jab batteries both charge from my 250w of solar.
My EBL is 99. See picture.
Steve and Denise
Steve and Denise
5,294
14,092
Spalding LINCS
A Class Carthago
Since 2008
@Lenny HB can you think of any reason the voltage on these slave displays would read so much apart, I assume the ebl controls everything and the display is a mimic of that ?
Steve and Denise
Steve and Denise
5,294
14,092
Spalding LINCS
A Class Carthago
Since 2008
This panel is only a slave to the ebl or so I thought but the old one read 12.6v then I fitted the new one and that reads 14.3v so I put the old one back and it reads 12.2.
As this panel is only a slave I can’t understand why they both show different voltage only minutes apart,
Shouldn't have any effect on charging the panel only monitors the voltage via the EBL.
Fitting this new panel seems to have corrected all these strange readings, I have checked batteries with a meter all seem to read correctly now.
I hope this makes sense.
Lenny HB
53,435
150,026
Hymer B678 DL
Nope, the EBL doesn't have display. you trying to confuse me 'cause its not hard.:D2
