Sargent control panel
Buster668
swift kon-tiki 655
The Sargent control panel I have has recently started to display the vehicle battery voltage as 0 or 0.1 (poor) when I know the battery is fully charged. What can I do to rectify this? I suspect it means that I cannot use the built in charger for charging the vehicle battery because the control panel thinks the battery is knackered when it’s not!
First course of action is usually remove control panel,disconnect ribbon cable,leave for a minute or two then reconnect.
This also means that the control panel won’t allow me to switch between vehicle and leisure batteries
if you are looking for some one to repair or can give advice speak to Andy Carter in leicester. he fixed my control panel last week very nice chap.07549160204
If you have an auxiliary fuse box usually behind the drivers seat,I would check that for damaged connections into the bottom of the circuit board.Think it’s called an EM40 controller.
