Same size battery? (1 Viewer)
Happy1
516
220
Wales
Rapido A class
12 years
Trying to add a second leisure battery, the existing one is 85 amp, is it ok to add a 100 amp battery?
Any advantage or disadvantage?
From my wallets point of view I already have the 100!!
43,332
49,504
Add any size you like.
The charger and 12v system only see them as one battery of combined capacity.
In this instance one 185ah battery.
Age of battery does matter though.
Ideally they should all be around the same age....within a year or so if they've been looked after and not repeatedly over discharged.
The only disadvantage is the higher the combined capacity, the longer the charge time.
Happy1
Happy1
516
220
Wales
Rapido A class
12 years
Thanks papajohn, is it ok to mix AGM and gel? The charging rates seem similar depending on which suppliers fact sheet you read.
Lenny HB
53,475
150,183
On the coast in West Sussex
Hymer B678 DL
No, AGM require the absorption charge to be 14.7v and once up to that needs to be held for 4 hours for a full charge, Gel the absorption charge is 14.4v and needs to be held at that for at least 8 hours for a full charge.
A Gel on AGM settings will shorten it's life, AGM on Gel settings will never receive a full charge and you will be lucky if it lasts much more than a year. AGM's are a bit of a disarster for leisure use, Hymer group have been fitting them for a few years, they are holding up a bit better since they started fitting proper AGM chargers but still loads of reports on German forums of them failing. I would steer well clear of AGM's.
May 7, 2016
7,261
11,749
West Sussex
Carthago Compactline
Since 2003
I was told when I purchased one of my motorhomes that both batteries needed to be of the same size, type and age. The advice of one battery manufacturer can be found here
Go to pages 20-21
Happy1
Happy1
516
220
Wales
Rapido A class
12 years
thanks pausim, it also recommends the biggest single battery that fits, something i had not thought about and have plenty of space.
TerryL
6,188
8,191
North East
Low Profile
Ideally you should fit two batteries of the same age and type, and as big a capacity that will fit. But as papajohn says, no problem in what you're doing, but don't mix types.
43,332
49,504
Go to pages 20-21
Nowhere does it state 'same size'
May 7, 2016
7,261
11,749
West Sussex
Since 2003
If you read what I wrote I didn't say the advice about same size batteries came from the battery manufacturer, I clearly only attributed this to the seller of the motorhome. Indeed I did not claim to qoute the battery manufacturer at all, I simply provided a link that I thought might be helpful.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
and banner are a battery i think anyone should avoid . they seem to just live a little bit longer than the warranty then let you down .
having a garage for years and hearing others talk i dont rate them at all.
BMM
205
176
Essex
I'm a Newbie
I have 2 leisure batteries and room for a 3rd, last week I asked exactly the same question to my mechanic and he insisted all 3 need to be the same. I'm going to buy 3 new ones just to be sure
43,332
49,504
