Thanks Alan. With your reference, I also managed to find it on Amazon.It’s a little black dome no bigger than a finger tip probably over the entrance doorhere’s one
Truma Room Temperature Sensor - 34020-00263 - Truma - Caratech Caravan Parts
Truma Room Temperature Sensor . Part no. 34020-00263 Fits all models . 100'S of other NEW parts available for caravans, motorhomes and boats...caratech.co.uk
It does sound like it’s suspect at £30 for such a small thing it’s worth trying and if it turns out not to be the problem at least you’ll have a spare this link may be of help?Thanks Alan. With your reference, I also managed to find it on Amazon..The reason Iam thinking it is the sensor is because when I put the setting to 4, it gets very hot. Then down to 3 it switches the boiler off. The boiler stayed off unti we woke up frozen in the MH. Temp inside got down to 11 deg. The sensor did not pick it up. but back on 4-5 it worked. back to 2-3... it does not trigger the boiler. Are my assumptions correct?
Thank you for this. So for a family of 3 we have to take it in turn to have a showerMou and Iryna The Truma combi heater (For heating and/or hot water) is not like a house combination boiler and does not supply hot water on demand , It needs time to heat the water that it holds and then needs time to heat the replacement water as it refills during use.
I do not think they are normally serviced . But Truma do recommend that it is descaled on a regular basis.
Thank you Alan for the comment and the link. Yes you are right. I can have the thermostat delivered in 1-2 days. It seems easy to install. I will try to locate it this morning. I was told it is by the front door. I will look around the passenger and driver's door. Thank you for the link. I shall, for sure, read itIt does sound like it’s suspect at £30 for such a small thing it’s worth trying and if it turns out not to be the problem at least you’ll have a spare this link may be of help?
How does the Truma Combi heater work?
With a detailed structural drawing, we show you how the Truma Combi heater works. Find out more.www.truma.com
I have looked everywhere by the entrance door, both of the driver and the passenger door. I cannot find anything that resemble what you sent me. Does any have a Fiat Ducato Chassis with Truma Boiler who would advise me the exact location of the thermostat? Thank youIt’s a little black dome no bigger than a finger tip probably over the entrance doorhere’s one
I do not have a contro panel. The boiler is inside the cupboard. Maybe I need to check there??Some of the older rotary controllers had it built into the back of the controller.
You must have you were saying "when I put the setting to 4, it gets very hot. Then down to 3 it switches the boiler off."I do not have a contro panel. The boiler is inside the cupboard. Maybe I need to check there??
