Kerry9
- Sep 16, 2018
- 79
- 58
- Motorhome owner
- Rimor Sailer 645 2.7 TC fixed rear bed on Mercedes chassis and engine.
Hello All, Season's Greetings
Our Arsinicill (or similar spelling) digital control panel appears to be malfunctioning and the navigating buttons appear to cause it to either show the time, or turn off. Pressing the short cut switches along the bottom cause the display to emit a high pitched buzzing noise for a second - then it shows a crazed pattern of all possible symbols - then goes blank.
It is currently hooked up to the mains but I can't make the panel display the 'exterior supply on' option, although all lights and boiler and pump seem to work - but am not sure if this is off the battery or off the mains.
The display worked perfectly on its first an so far only run out for a weekend, in October, now it is dysfunctional. It has not moved off our drive since then.
A new unit even if I can get one for this 2002 model, is apparently not much short of a grand I read somewhere online. But then someone else said to access the external battery hatch, find, by feel, some kind of on/off rocker switch, turn I this off then on again, and this should apparently rest the display.
Any sensible suggestions would be most welcome fo this non-electrics newbie to motorhoming.
