Removing Para Press roof window
Tinwolf
4 years
I need to remove my motorhomes main roof window to replace the seal but I don`t know how.
The label says Para Press 5 V-X/B 43 R-001736, it only opens a short way so I can`t reach the fastenings I can see.
Does anyone have an idea?
Are you removing the whole hatch or just the moving part?
I want to remove the clear, window part of the opening so I can replace the seal as the current seal allows wind in.
It looks from the photos as though removal is done from outside?
But how?
I'm guessing if you remove the hex nut on the slider (both sides) you should be able to stand the window up a lot higher, then get at the screws on the front hinges ?
I can remove the front nut but I can`t reach the back one
The clear top is usually held in place by 2 pins on the hinges 😉
The rooflight is not ment to be airtight !
Did you resolve this. I'm having the same issue trying to remove the clear window
