Reich water pump replacement- Burstner T-Star (2005)
Leeds, UK
Burstner T-Star
I’m looking to buy a spare replacement water pump for our Burstner T-Star 695 (2005)
I don’t have access to the Moho until a day before our European trip
Can anyone point out what pump is fitted/needed please so we can buy a correct replacement?
All i remember is stating reich on it
I just ordered a Reich pump yesterday so I know what is available.
If your pump is in the tank it needs to be a submersible type.
As you probably know, they vary on flow rate in lt/minute and pressure in bars. You need the pressure according to the height of the 'lift' needed from the level of the pump to the shower head.
Ours for the Arto is 15lt/min and 1.0 bar. I estimate our 'lift' to be 2m.I think that should suit most MHs. 0.5 bar may not be enough and something like 2.0 bar could test pipe joints, and they have high flow rate so use more water.
If you cannot get a definitive answer, either call Burstner or go for the 15lt/min 1.0 bar - unlikely to go wrong.
Thanks for you in depth reply
I’ve managed to take some photos of mine
Is this a reich one do you know ?
From your photos it looks the same as the one in my LMC motorhome which is the reich twin motor 19 litres per minute. I purchased one from eBay last year at £54.00
