Stealaway
- Jan 8, 2013
- 8,496
- 11,541
- Burstner Lyseo 690G
- Happy FLT since 2011
At the end of last year I noticed the red charging/alternator light was slow to go out.
I was told by a mate that you can change the voltage regulator and brushes in situ - really??
Let have a go then ------- He's no longer a mate!
It can be done - but it took best part of 3 hours and much swearing.
The regulator was £28 from Ebay. -https://www.ebay.co.uk/itm/BOSCH-Alternator-regulators-F-00M-144-128/192098356965?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
I took a photo of it to check the number, it can be seen. My 2012 ducato one was - F 00M 144 128
The alternator is quite deep down the back of the engine block on the left.
There is a plug, easily seen, that first needs removing.
There are two mate nuts and a m6 phillips screw holding the plastic cover that masks two of the phillips screws in the regulator. There is a mate nut holding the red /live cable. I pushed a piece of hose over this when it was loose to stop it from shorting. (I couldn't be bothered to get to the battery and disconnect it).
The voltage regulator and brush holder is held on by 3 x m4 phillips screws.
The brushes were worn but not seriously and this van has done 45K miles
The light now goes off immediately and I have a slight increase in charging voltage - all good and worth doing. I imagine a garage would take the alternator off and simply replace it for a bit more than £28.
Selection of tools needed - long 13mm sockets and short phillips screwdrivers.
The led extending mirror was very handy - £4.99 Ebay.
