Rear view camera
East Anglia
Kontiki 669
Since 2010
My rear view camera stopped working while away in Cornwall last week for no apparent reason. Hopefully it's only a fuse or something simple, but I can't find where the fuse is located. Anyone know where I can find the fuse please?
May help if you say what van you have and the type of camera setup. Also if it was factory fit or aftermarket. Then someone with the same van may be able to help. Hope you find a solution.
Its a Swift Kontiki 2013, there is no make on the monitor that I can see,but I will attached a photo of it.
Reactions: 68c
Also a photo of the camera please. Also photos of the connecters showing the pins. If you are lucky the van will have come with some history, bunch of receipts showing work over the last eight years. Look carefully as the receipts may not be that obvious, faded etc. Hopefully that will give you the info you need to sort things. As the monitor is built into the rear view mirror I assume you only need a reversing function so only need a cheaper single camera setup should you decide to replace it.
I have that system, I have my manuals to hand so will have a flick through and come back to you.
Not much help but this is all I could find in the books.
I had same problem myself it just went off while i was driving along. Swift Kon-tiki 625 2016.I took it to dealer and they found that it was fused via the 12v fridge fuse!
I am awaiting a new camera as one of the lenses is fogged up. V1 reversing foggy, V2 rear view ok.
Hopefully this helps.
Thank you that would be really helpful👍
