We have a reversing camera that has the monitor over the rear view mirror. It only works when reverse gear engaged. But it would be useful as a camera to view a trailer and a bit of the road behind the van as it is quite a wide view lens.
I’m thinking disconnect whatever feed from the reversing lights and connect a permanent ignition switched supply. Without ripping out some back wall panelling I cannot see if there is a single or double signal cable coming out of the camera in order to power a second camera.
I have absolutely no idea when the 12v to the camera is fed from. Up front from the reversing light switch or from the reversing lights in the rear cluster. Or from the Canbus somewhere?
Someone may have done this before. Any ideas please. If not I guess a wired second camera system is the way to go but that is a lot of wiring to hide.
TIA
![IMG_0107.jpeg IMG_0107.jpeg](https://www.motorhomefun.co.uk/forum/data/attachments/780/780643-b379d9d4b47cc78373878377698761e9.jpg)
![IMG_0106.jpeg IMG_0106.jpeg](https://www.motorhomefun.co.uk/forum/data/attachments/780/780644-ea0b322c595c3cb03f7c2b85c97adf77.jpg)
TIA
