Rear lights, indicator and break lights not working (1 Viewer)
Aug 17, 2022
268
141
Middlesbrough, UK
Adria Supersonic 890
So, I have just had an A frame fitted to our fiat 500 and hooked up to our swift kontiki tonight for the first time. It is a Fiat ducato 2.3 180bhp. As soon as I plugged in, everything on the rear of motorhome has stopped working, lights, indicators, reversing lights and break lights. Everything else on motorhome is working, only rear lighting elements. When connected no lights on car either!! The car all works fine when I disconnect. This is the first time we have hooked it up. Any ideas anyone? Thanks
Dec 24, 2014
8,476
41,805
Hurstpierpoint. Mid Sussex.
Compass Navigator
Ever since lighting was by Calor gas.
I think you'll have to depend on the fitting firm to sort it.
Modern vehicle systems are pretty sophisticated and if you fiddle about with doing any suggestion on here the fitting firm won't be very appreciative/understanding/co-operative/sympathetic.
But you can't do much harm checking the relevant fuses to see if any have blown.
4,113
77,580
EAST ANGLIA
Murvi Morello
Since 1975
Yep I have emailed them, my gut tells me they have made a mistake with the wiring!!
or a fuse in your van has blown and when you plug your car in, it uses the same circuit?
8,399
11,386
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Did he fit a cam bus conversion box. Modern vans will not work when simply connected to the wiring
Adrian140974
Aug 17, 2022
268
141
Middlesbrough, UK
8,399
11,386
Burstner Lyseo 690G
I'm not sure if they installed that, I used Towtal in
Stoke
Sorry not that one this one.
It's worth asking them my 2012 van needed one
Adrian140974
Aug 17, 2022
268
141
Middlesbrough, UK
Happy Jim
336
507
Wokingham
Rapido 9095DF
Since June 2017
I had this, old van wiring for tow bar, and a new (to me) fiat500 toad. Exactly as you describe, solved with a replacement tow bar electric kit.
Jim
Adrian140974
Aug 17, 2022
268
141
Middlesbrough, UK
Jim
Oh right sounds straightforward, the van and towbar is not 3 years old yet but I suppose could be the issue. Thank you
