Rapido V56
Van Coversion
I have a couple of questions to do with our Rapido V56. Firstly, how do I remove the lights in the pictures attached to replace? After consulting the manual I am non the wiser. And secondly on the outside vent cover, (also photo attached) if I remove, clean off the flaky silver - can I respray with some silver spray?
Thanks in advance for any advice.
Paul
Lights one I think the small ring around the bulb pulls or twists out leaving the switched base insitu, second bulb the whole thing should be pulled down held in place by 2 wire spring clip each side that compress as you pull them down.
Plastic vent yes and yes - if it is a hot vent get heat resistant paint and a good plastic primer or the paint will come off as quick as you put it on.
Thanks Clivefog. The advice you gave was spot on. The second bulb I can see what I need and how to replace it. The first one (see attached photo's) which part do I replace and where do I get it? I would think the whole unit?? The plastic vent I think is the fridge but to be safe I will get some heat resistant paint and a good plastic primer. Any recommendations on what to use?
Not sure I guess it is attached to the switch? Have a google for 12v light bulb and see what you get. Best of luck.
