Rapido replacement locking fuel cap
weekenders
Leicestershire
15 years
Tried eBay, no luck, trying to find a replacement locking fuel cap for our Rapido 985f 2004 model,50mm any ideas?
Is it a fiat. If so I'm sure you need to look for fiat not rapido. I have a rapido and the base vehicle is fiat
I think the key to open it is the same key to start it, then as others have sent it's a fiat part not rapido.ours is a rapido & fiat key opens fuel cap.
it will be a standard A Class one, not a fiat one. When I lost mine I got one from ebay. Have you tried the water filler cap for size? when I done mine the water filler cap was the same, fitted perfectly and I got one of those instead.
Mine is the same key as the ignition.
Think it will be standard
I was going to say, more or less, the same as Haggers. Our water and diesel locking caps are the same. As is the one in his link.
Or there is this one.
Sorry if you have already looked at these and we are going over old ground.
mine is also A class Rapido. water cap is same keys as lockers etc.. but fuel is same as ignition
a decent locksmith will do a barrel to fit your key, may even stock the cap. save having another key to worry about.
