Rapido external panels uncovered (1 Viewer)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Not many people get to see under the skin as repairs are usually consigned to dealerships behind closed doors.
So as I have panel damage going back over two years I'd been keeping an eye out for the part I needed without paying Rapido prices and UK concessionaire mark ups.
Picture here of a longstanding wound.
Replacement corner found for £200 with some haggling
So the first job to enable removal is to take off the lower centre section.
All panels are held in place with "mushrooms" a trade term?
Sometimes they will pull out but to avoid damaging the flexible centre section I used a saw from below to relieve the 5 fixings
Then after removing all screws and disconnecting the wiring harness you can pull off the corner section
Lighting wiring harness transferred to new panel and new mushrooms fitted
New corner panel in place, this is quite fiddly and a point where one is likely to think I wish I'd left it to a specialist :LOL:
Centre section brought home for a serious clean up and service of the number plate lights
To be continued........
Mr B
990
1,889
Yorkshire
Rapido 7065ff Design Edit
Since 2015.......
Me too.
Couldn't you get your old damaged panel repaired?
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
If I repaired it I'd then have to have it spray painted and then have to have the other corner at least painted too. Just not worth the effort as the rest of the panel is in poor condition anyway.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Corner panel removed and refitted three times until I was as satisfied with it as possible. It pays to put some grease on the pins as they can be quite hard to drive home. Sikaflex behind fixing screw points to prevent cracking and vibration.
Wiring harness rejoined and number plate lights reconnected. ready to refit
Refitted
Replacement Chrome trim similar to Rapido but ebay
Job done
Dec 29, 2012
505
30,697
Cheltenham
Rapido 7066df
Since 2014
Looks great, I've missed the regular modification threads of a couple of years ago.
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
A repair job to the LED side marker light
They had cut so much length off the wires and used through crimps that had corroded. Soldered on some new tails and heat shrink sleeving
Jokon replacements are about £12 delivered
EDIT these are not polarity sensitive
Source of replacements
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Along the bottom of the panels where they overlap Rapido use different methods to fasten them together including rivets but they're all a crap job.
I re drilled the holes and used these Citroen reusable fasteners
Apr 18, 2009
3,569
3,367
Englishman in Mid Wales
Hymer B584, A Class
Not long enough!
Feb 23, 2015
104
173
Winchester
I know this is an old thread - But please can you let me know where you sourced the' mushrooms' from? we need to sort out our door trim on a 2008 Rapido A class.
Apr 13, 2020
43
49
Fiat Ducato Rapido
since 2018
Hi OldWoman here, did you find out where he sourced the mushroom clips from.
17,592
43,006
ebay usually has a few sellers although some ebay shops are closed at the moment
Apr 13, 2020
43
49
Fiat Ducato Rapido
since 2018
thanks for your help these clips seem very hard to get
Feb 23, 2015
104
173
Winchester
Hello oldwomen- my husband has scoured our old orders and can not find or remember where we purchased the mushorrom clips from, sorry. However he says look up awning or tarpaulin clamps on Amazon or ebay or check with Wokingham motorhomes ( Rapido Dealer) Have you joined the Rapido owners club as they are very helpful?- hope this helps.
Apr 13, 2020
43
49
Fiat Ducato Rapido
since 2018
Hi thank you so much for letting me know. I will look on there web site. If i persevere enough i will get there in the end. Thanks once again, keep motorhoming.
Feb 23, 2015
104
173
Winchester
Hello again old women,
My husband thought I was asking about the awning and some clips we got for our sun shades , so disregard that sentence!!
He is looking for the few clips / rivets we had left and if they are still in their packet we can get a part number for you.- he remembers buying the rivets from a dealer , he thinks Brownhills - Approx £8 fro a handful.
Feb 23, 2015
104
173
Winchester
Hello Old women- we do not have any left , only kept some off the used ones just in case and no part number. My Husband is sure that he phoned up a Rapido dealer ( Brownhills?) explained what they were and sent a photo , we then received the correct ones.
Again- hope this helps , sorry we can not be more accurate!
In hind sight I should have replied to my own post and let everyone know where we got them from at the time!
Apr 13, 2020
43
49
Fiat Ducato Rapido
since 2018
Hi Mici,
If he can find the packet that would be fantastic, fingers crossed thanks once again.
17,592
43,006
if you measure one of the old ones, search ebay for fir tree clips of that size. There are hundreds of different sizes and types. If you can't find an exact match, there will be something that will work
Techno
Techno
Jul 28, 2010
15,475
20,756
May 2010
Sorry everyone I never got any alerts to the question asked about mushroom studs.
Wokingham motorhomes dealer
Jun 22, 2012
231
130
Ebbw Vale Gwent
Rapido 9048df A class
seven
Hi Techno I know it's been some time since you prepared the corner of the Rapido where did you manage to get the part from as I need the left-hand corner at the moment and I'm having no luck.
Regards Ray
17,592
43,006
Regards Ray
What age rapido? I have a full rear bumper in the shed
