No idea if it is SUPPOSED to do it, but last winter we was parked next to a Rapido and I was alarmed to see something pouring out the bottom !That's very helpful @Minxy Girl and thanks , but do you know wether the water is supposed to drain behind said cosmetic panel? At least ours made it to 8 years old
Jim
I suppose it could have been sealed originally, not for water ingress issues, but simply to secure the panel, the shouldn't be any issue with it going behind as it is just a cover and not meant to offer any water ingress protection as such, if it was it would be done differently with it slotting under the overcab 'pod' bit.That's very helpful @Minxy Girl and thanks , but do you know wether the water is supposed to drain behind said cosmetic panel? At least ours made it to 8 years old
I wouldn't if I were you, you would risk cracking/splitting it, if you're concerned I'd just clean up the top and side edge and seal it, this will also ensure that the panel is tightly fitted so less likely to flex and crack as you travel etc.I s it easy to get the joining panel off to inspect?
There's another make of MH that has a similar set-up and the owner thought there was a major issue with it ... can't remember what it was now though.No idea if it is SUPPOSED to do it, but last winter we was parked next to a Rapido and I was alarmed to see something pouring out the bottom !
Went and spoke to the guy when it stopped raining and he assured me it was quite normal and had been the same from new![]()
Yessss... seem to remember there is one that the whole front overhead cowl is simply for looks and fills up with water... always thought that was a REALLY daft idea !There's another make of MH that has a similar set-up and the owner thought there was a major issue with it ... can't remember what it was now though.
Wasn’t that a Bailey?There's another make of MH that has a similar set-up and the owner thought there was a major issue with it ... can't remember what it was now though.
