Hi, any advice would be very gratefully received. Trying to remove the fan blades from a car heater fan motor - the motor doesn’t work but to unbolt it from the housing the fan blades have to come off. Does anyone recognise the bolt/fitting holding the blades to the motor shaft? Not sure if it unscrews or pulls off - the blades are probably quite brittle so not easy to clamp them without damage! ( It is from a 1970 Triumph Spitfire if that’s any help - though it may not be original as there was a major renovation in 1996 ) The motor and heater matrix do look original though.
Thank you for any input!
Cheers, Simon
Cheers, Simon
