Pressure Indicator
Tyneside
Chausson best of Flash 10
Several years now
Found this in the depths of the garage. Digital Pressure Indicator. Range 0 - 20B. No calibration cert, but no reason to suspect it is inaccurate.
Be aware that the plastic pipe attached would only normally be used up to 7B so to use the device on higher pressures I'd recommend a different pipe. With carrying case.
£25 + P+P (which I'd think would be about £3-50)
We used them on gas. I have another one which I use for very accurate measurements of tyre pressure. You could NOT use it to do a "drop test" on the low pressure gas (after regulator) supply in the MH, as the range is too high. But could use it to check for leaks on a higher pressure system. Not sure if putting liquid in them would stuff them, it's something we never did.
