Peugeot boxer airbag warning light come on
Reading
Elddis Accordo 125
Since 2015
The airbag warning light has come on my Peugeot Boxer 2017 Motorhome any ideas please?
One possibility is an issue with the airbag ecu. That was the issue with ours. A number of threads on here about it.
Another possibility is wiring trapped \ cut under the rotating cab seats.
Unfortunately it is a very common problem.
We have just had our airbag ecu replaced under warranty by Fiat.
If you can confirm that it is the ecu and not some other cause, Crashdata can repair it, but you will need to remove it and send it to them.
Apparently trying to start the engine when the starter battery is low can cause the ecu to fail.
