Pegasi 590 Engine Battery ??
OTR Again
Since 2002
Hi,
Looking to buy a tyre inflator so we don’t have to visit the garage every time we want to top up. Most recommendations are for inflators that clip onto battery terminals. Had a look under the bonnet of our Roller Team Pegaso 590 and also in the Fiat user manuals and can’t seem to find any relevant info. Then we looked for the engine battery and can find the cutoff switch under drivers seat but no battery.
We were probably told this info when we had our dealer handover but it was information overload and can’t remember and it’s Sunday. Any help appreciated by this newbie.
The battery is most probably under the passenger side floor.
Under the bonnet there should be a 'jump' post for jump starting and external charging.
It will be under a plastic cover, possibly embossed with a lightening bolt.
Connect to that and any metal part for the earth.
If the inflator won't reach the rear axle use the leisure battery.
as pappajohn has indicated on a fiat chassis the jump start post is on the right of the engine bay as you look in just above the fuse box cover there is a black plastic cover sticking up with a hinged cover on it.
lift the cover and clip on the positive.
i know you have an A class but the neg is usually a stud on the slam panel in the right hand bottom corner.
cab batter is under passengers feet
Thanks for the responses, I'll wait until it stops snowing and go take a look.
