Depends on budgetHello all!
I'm thinking of buying a medium van to convert into a camper but what's the best base van to start with? A plain old panel van or a crew cab style with windows already fitted?
Thanks so much.
Thanks so much.
Definitely agree on the condensation aspect for single glazed crew van original fitted windows. I would get a panel van and fit my own proper camper windows..Depends on budget
Main drawback i see for single glazed windows is condensation and generally non opening
You can buy the swivel mechanism. It just clamps between the seat and the base.Thanks very much everyone for the advice. I'll get me a panel van then. Regarding the cab swivel seats can I fit these myself? Is it a hard/easy job? I'm a tradesman so I'm practical and I did convert a transit many years ago but at a basic level. Also, how easy is it to remove the bulkhead - thinking of buying a vivaro H1L2. Cheers
Yes & yes.easyRegarding the cab swivel seats can I fit these myself? Is it a hard/easy job?
I agree, there's a lot of compromises. But it's also enabling the cab to be used as living space when you're parked up.Some may disagree but having considered swivels I felt and observed in manufacturers vans they have more disadvantages than advantages in a mwb pvc..the drivers swivel is often restricted by furniture ,the passenger is across the side door ,the height is wrong,they heavily dictate the whole vehicle layout..even down to the need for cab blinds or screen cover,instead of a simple curtain.
Look at what's available for different vans I would say the Ducati type has more conversation/upgrade stuff than any other except vw
To prevent the airbag light from coming on from the removed middle seat, my van just had the unused seatbelt receiver still connected and just zip-tied up inside the passenger seat base to stop it rattling around.I didn't plan on making the drivers seat swivel, didn't even come to mind really! I think I would just want the passenger seat to swivel? Rewiring the seatbelts/ECU sounds a bit of a faff? Maybe there are companies out there that can do it for you. Thanks all.
Interesting, I'm looking at either a transit or vivaro, so a double cab or windowed van would be classed as mixed therefore higher speed limit?? Good point about the length, tbh my driveway is short about 6.5m so I think it would be awkward to work on a LWB van.I’d go kombi as it will be classed as a dual purpose vehicle and as such normal car speed limits (I’m assuming you want a VW Transporter type van).
As to LWB or SWB, I road tested both versions of the T6, you can park a SWB anywhere but the extra 300mm makes a world of difference if you want to use it as a daily driver - I’d recommend a test drive and simply take it to a local car park and see how you’d feel walking away from it.
I think the common layout for a Viv/custom/dub is rock and roll bed at rear, kitchen on far wall and folding table? Not sure what a dinnete is? CheersLength of van depends on where you want the bed, shorter vans may have the dinette converting to bed or no dinette and a bench seat arrangement at rear.
I suggest you first go to a number of dealers and look at layouts, decide which layout you like then find a van you can build out to that layout or a version. That’s what we did and it saved us going through the 3 Van routine.
if you end up with a fully converted campervan (ie compying with the DVLA guidelines, then it will be subject to the same speed limits as a car (if sub 3005kgs unladen) regardless of it being a dual purpose kombi or not.I’d go kombi as it will be classed as a dual purpose vehicle and as such normal car speed limits (I’m assuming you want a VW Transporter type van).
