Scout
- Apr 4, 2009
- 4,009
- 142,820
- chic c line
- 12 years motorhoming, a lifetime of living
I stupidly raised the dish with a skylight fully open, the LNB jammed against the raised skylight, I managed to lower the skylight then retract the dish. once the dish was retracted I again raised it it and seemed well on both LNB channels and did so for a few raising / retraction operations
After moving to a different place, the dish was again raised , but would not lock on despite having a perfect line of sight, I checked the led it showed E9 error which I believe is open/closed short circuit error, I have checked the internal connections and will today hopefully be able to check the LNB connections. I did notice the LNB auto skew was at 90 degrees which seems out of normal?
Are the LNB connectors the same as standard f plugs ?
any other tips before I start please
