- Apr 6, 2019
- 4,734
- 9,473
- RV
- FourWinds Windsport 6.8L V10
Not my photos.....
That’s a short slip road which you have to brake for the sharp turn up hill. The volume of traffic now to when it was built is a lot more.Hi looks like just before the turn off for Brownhills at the A46/A17, All ways getting tail backs there getting off the A1
Concerning how much the rear chassis has moved looking at the angle of the rear wheels
Good news no injuries. Hope they took out the insurance waiver when hiring
In which case they should do something about the speed on the A303Sounds like the A303/A34 interchange. They should reduce the throughline on the A303 to one lane to give joining traffic a fighting chance. Entry is a very tight bend, steeply uphill, with little more than 50m merge zone with A303 traffic bombing through at 80mph.
Whats wrong with just reducing the speed limit if the current one is dangerous?It's better to engineer the road to handle speed safely. This could be easily done by dropping a lane on entry to the junction and gaining one as the traffic merges. This also has the benefit of allowing a much longer decelleration for leaving traffic. Unfortunately, widening to allow more room would require lots of bridge engineering, whilst the other solution involves a pot of paint and some signs.
The are actually two on-ramps westbound at this junction. The second one isn't nearly so tight and is not space constrained by the bridge, so that can continue to merge on as normal. The eastbound on-ramp is even shorter than the west, but the turn is less tight and downhill, so you've got a better chance of getting some speed.
What you’re suggesting then is because one vehicle/driver cannot use the road correctly then every other vehicle that managed to use that section of road correctly has to suffer reduced speed limits therefore longer journey times. I would rather just see the problem driver dealt with appropriately than everyone else having to change.Whats wrong with just reducing the speed limit if the current one is dangerous?
Cos nobody would take any notice.Whats wrong with just reducing the speed limit if the current one is dangerous?
But they had that on the M25 & at every exit losing a lane traffic came to a complete stop then back up to 80mph then another complete stop. That only works if you have multiple lanes in each direction far in excess of existing traffic capacity.This could be easily done by dropping a lane on entry to the junction and gaining one as the traffic merges.
Unless signed lower 70 is the limit which in reality would be 80on a dual carriageway?
