Omni Step - Fuse location...
Fletton
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
Hi folks... I've just blown the fuse to the step on my Knaus Sky I - A class... on a Fiat chassis (2015)
I was faffing with a sticky door switch and managed to short it...
I even thought I heard the fuse blow... so assumed it to be not far away.... inside the Moho... but I'm b*ggered if I know where to find it...
I believe Step is on a perm live... So I looked under rear bench seat first where there is a connector block... but no fuse/s... that looked suss..
Checked all fuses on EBL under passenger seat... tho guessed it wouldn't be on there anyway...
Pulled all fuses I could find under driver seat... no joy...
Pulled other rear seat out where ignition step relay hides - no fuse nearby...
Any Ideas.... i.e is it likely to be on the Fiat fuse block to right of steering wheel...
John
Edit:... think it's same circuit as TV... I'll check tv fuse....
No its not... i'm talkng rubbish... I caught tv plug whilst faffing ... tut!...
Good Morn Funster Folk
Any takers today?!! ... :)
Which EBL is it? I have an EBL101.
The step fuse is marked 'Grundlicht/Trettstute'. It is a Polyfuse self-resetting fuse. It protects the step and step light circuits.
It should reset itself after a short period, when it cools down. If not, it could have failed. Try pulling out the Polyfuse and replacing it with a 10A standard fuse, just to see if that gets the step working again.
@autorouter ...
I have the EBL 251 ...
I looked for those "words" and went straight to a blown standard 20A fuse..
:dance:
Don't know how I missed it first time.. :doh:
John T
