P
paulmj
Guys,
There is a whole long saga revolvong around the alternator in my RV. I won't bore you with it here, but here is a synopsis of my current issue (I hope, rather than problem) taken from the RV section:
"Well the problem seems to be solved - or the plot thickens............
I managed to find a brand new replacement alternator on US ebay. I can't believe I didn't think of it sooner. I just looked through the pictures until I found an alternator that looked the same. Job done. I got a direct replacement, 130A job delivered to my door in 6 days for £85 including insurance! I was amazed.
I've just fitted it and almost all seems well. When I start the engine it behaves as ait should. So the old alterantor was definitely duff and causing all of my problems. However, the new alterantor gets too hot to touch after about 60 secs of running.
It isn't an alectrical issue as with all of the electrics on and the ignition switched on it doesn't get hot. It is only when the engine is running.
So, is this likely to be because it is a brand new alternator and the brand new bearings are a little tight and need to wear in? Or is it just that the batteries are a touch low and it is having to work hard while brand new? I've put the genny on for a bit to top the batteries up and I'll try it again.
A big leap forward and the electrical issues seem to be solved.
But I'd be grateful for your thoughts on the heat issue."
I think it is getting 'a bit less hot' each time I run it.
I'd be grateful for your thoughts on the heat issue.................
Many thanks in anticipation.
Paul
Paul
