I've got a Lunar homecar P59 on a ducato chassis 2007 , had it a week
First purchase was a carbon monoxide alarm ,only I'm a bit out of my depth with getting the water/shower/heating right
There's a water fill point on the side, spec sheet on the web says 100L clean 85L dirty capacity , previous owner bought it from a dealer but never used it , never slept in it just did three 50 mile day trips in it before his wife took ill and died so it's never been run from buying it from the dealer june 2019
He did have a problem with the starting battery going completely flat even though it was permanently plugged into the mains, it was that flat it needed replacing as it wouldn't hold any charge at all
The control panel shows this picture which i believe means the boiler has some water in it
When i press the rocker switch the other way the other battery which im assuming is the starter barrery isn't at 100% despite being charged all day
So do i just fill it from the outside and open the taps to bleed it or flush it through by opening the grey waste valve underneath
The truma manual mentions something about an electric safety drain valve but ive no idea where that is
