Coolcats
- Jan 24, 2019
- 6,464
- 11,728
- HymerCar Ayres Rock
I purchased this product as it was advertised as a quick and easy fit, having used several other wheel locks this seemed a simple and compact solution. I purchased this from Southdowns, it arrived wrapped in a box when I opened the box there was an orange storage bag that the Lock can be stored away in. The instructions are comprehensive and i found them straight forward. The enclosed wheel bolts fitted my MoHo but some vehicles will have differing sized wheel bolts and these have to purchased separately so its best to check.
It took around 10-15 minutes to get everything out of the box, Two wheel bolts are changed out for the ones that accept the Nemesis Lock, only one Bolt is required but depending on where the wheel stops when parking will determine which wheel bolt to use. The advise is to make the Wheel lock fit snug against the wheel and there are some adjustment shims you apply for the first set up. The back of the lock has soft foam to stop damage to the wheel and the two Bars the extend, one through the wheel itself and the other around the tyre is plasticised again to protect the wheel.
Once set up 10 seconds to align and fit the lock is a fair assessment,
Pro's
As it says on the box its quick and easy to install, Foam and plasticised protection for the wheels, I like it as its compact and easy to dismantle and store
Con's
Like most physical security it would be possible to drill out the Lock, but not without making considerable noise and would probably take 10 Minutes and a lot of noise to do so. I am going to contact the manufacturer and ask if they would consider plugs for the wheel bolts to stop grit and dirt getting inside when driving.
Overall I am delighted with the product and is just one more thing added to help secure the MoHo from theft
Pro's
Con's
