Hello fellow travellers, we hope all is well.
We have made an unexpected observation whilst preparing our small motor boat for her boat safety inspection.
Background, we have purchased an electronic manometer in order to test gas tightness and are pleased all appears well as reflected by our bubble tester.
We decided on a manometer tester as we have seen youtube videos where small leaks may pass bubble testing and we currently have no gauge but are considering adding as a backup.
The butane gas was turned off and the gas was purged at the hob following testing, the manometer was left connected to the test point overnight reflecting zero mb pressure.
To our suprise the following morning the manometer was reading negative 30mb and negative 75mb by mid afternoon.
The negative was confirmed at the hob by holding a flame against the burner where the sound of gas/air movement was heard but the flame was not blown, seems air was being drawn into the burner.
This was firther confirmed the following day with a manometer reading of negative 60mb. This time we turned on the gas and watch the manometer move toward zero then to positive 30mb, we then lit the hob burner, turned the gas off at bottle and watched the manometer reduce to zero.
Our amazon purchased manometer has two terminals and is connected to the positive terminal and seems to be trusted by many gas engineers and has always returned to zero after testing.
We struggle to account for these observations and although pleased the negative pressure is being held, we are a little concerned with the size of the negative pressure and any adverse affect on our installation.
We ask if anyone is able to account for this behaviour or is in a position to apply a similar test or advise of anything we should be considering.
Thank you in advance
