Morning all,
Need some help. I think but not sure that I've spiked the Dometic fridge while testing for a positive to fit some fans. The front panel will not light up and also the oven above the fridge will not spark.
On the back of the fridge the control module Dometic 289 0241 20,
Has 230v mains power when connected.
On the 12volt connections, There's 14+Volts on the large red wire + 12 VDC with engine running.
On the smaller wires, PS 12 VDC connection there's a constant 12v.
On the D+ there's 12v with engine running.
I don't have power at the S+ or + although I did originally have something at +.
I've looked everywhere for a fuse in hope but do you think I've fried something in the module.
The motorhome is a Carthago S-plus. Wiring will be the same as the E line etc.
