Moving tyres on a M/H with TPMS.
Southport, UK
Wellhouse PVC Camper
Does the TPMS recognise the new wheel position if front wheel & tyre is swapped with the rear tyre on a 2018 Peugeot Boxer based M/H?
You have to physically change the tyres around and keep the rims in the original position with the tpms fixed to that rim.
A garage near me charges £12 per tyre to take a tyres off and put back on the requested rims.
,so for a back to front swap for all four it would be £48.
Thank you for that, will have to drop pressure in each tyre to confirm where they are located on vehicle. Thats the easy bit reinflating not so easy. He ho.
If they are already mixed then best to reduce the tyre pressure in one tyre at a time ,the pressures are indicated in the passenger door jamb.They are a hard ride but expensive for a dealer with the right equipment to adjust.pressure only .
They don't react immediately and when re inflated take a while to register correctly again.
Best to record each type pressure/ position and take it from there Only had one tyre on mine show a warning and took a while once reinflated to correct the TPM reading. I am about to have my spare and another new tyre/ wheel tyres switched around to the front tyres and keep the old ones as spares with one on the underslung rack
I use a Halfords 12 v pump to top up my tyres but I don't think it would be much use for a total flat tyre..
The boxer system is direct TPMS and relearning. Or you can use diagbox to do instantly.
Not 100% convinced that is is axle / side dedicated as this normally has a colour code ring on the TPMS stem. No boxer I have seen has this.
