Moving Seat Forward
FOLKESTONE KENT
Burstner A576
I'm a newbie
Hi, on my Burstner A576 the chairs turn rd but one is still way away from the table, so you have to lean forward which is uncomfortable, is there a way I can get the seat adjustment extended, as it’s at its max so won’t come forward anymore.
TIa
Martin
TIa
Martin
Problem with that is it will be to far away from steering and pedals when you turn it back to drive🤔 probably easier to move the table? Does the top on yours not slide in different directions?🤔have a look underneath and if it does there will be an adjuster 😊
You would need to find extended seat runners or buy a second set from a breakers yard and have both cut and welded together to make a longer set. Then the extension would need bracing to take any weight not supported by the seat base directly
If your table is the same as this I would fit an extension tab onto it to slide out on required side or possibly make a complete new top shaped to give more space on drivers side the only problem with that is it would not fold down to the wall so you would need to make the extension a hinged flap😊
Hi, it’s the passenger chair that is the problem
Oh I see well that’s going to be a bit more of a problem? Have you considered just fitting a small swing out table to service the passenger seat we have two that we fitted on our van and took the main table out completely The link below sells them.😊
I had the opposite problem - my table was too close.
Burstner had made a cut out to get it even closer.
I moved the table back by about 3 inches
