Missing parts from Omnistor 5002 awning?
MH04RMV
Cheyenne 632 SE
Hello Everyone,
Tried putting up the awning attached on my Autotrail Cheyenne for the first time since getting it.
While it seems all the sides/legs etc. are present, I think there may be missing a couple of bits that the side wall supports fit at/into at the awning rail end?
I've attached a couple of pics of each "awning end" of the rail, where I've managed to "hook" into the awning rail, which hopefully explains/shows things better...
Are parts "missing", or have I just not figured out how to correctly attach them (as they certainly don't feel secure at all)?
Thanks in advance for any hints/tips.
Cheers,
Rich.
Do you mean the top aluminium side bars of an omnistor residence room fitting to your awning?
There is normally just a [ shaped piece of plastic stuck to the inside of the awning box to stop the bar sliding
If you look on youtube for 'omnistor residence residence part 1 assembly' you will see rose awnings instruction video which shows the bits attached to the awning to hold the side bars
We have a very similar Dometic, ours actually clips onto the rail, yours looks to do the same, I have made a space filler (bit of plastic tube with rubber hose in to fill gap) when I first used scratched my head a bit, but once all tight it holds well, can be just thinking doing wrong, once in place and rigid it does not move.
Thanks busbuddy - watched the video, and I think I'm missing these x2 bits of plastic in pic below.
Hi MalcMc,
Any chance you could take a pic of your fix, to see if it's something that might work on mine please?
Cheers,
Rich.
Will do, I am away Friday, the part is buried in garage, will send photo
