Note: This feature currently requires accessing the site using the built-in Safari browser.
Try giving them a call as know they have sorted orders for others that way including RV owners - please let us know how you get on if you do.Trying to find TyrePal Solar 6 to buy, not on TyrePal website and 'out of stock' at Amazon![]()
Good luck with that method at 60mph.Past 48 years I've just walked around the vehicle, any vehicle, but usually only those I intend to drive, funny looks otherwise, even HGV's .... kicked the tyres and all seems to have gone OK ..... so far.
If you change the warning settings to suit your tyre pressures and temperatures for when they have warmed then it will not go off at all. Unless of course you start to lose any pressure.If it goes bang at 60mph your tyre pal will not forwarn you! I have it in my car. 1 lb pressure loss sets it off. Alowing for temperature change and speed pressure increases it drives me round the bend . I carry a digital pressure gauge and always have my daily walk round check. If you run a tyre at low pressure the walls will be damaged a new one is required .
Crickey !!! 60mph .... I only ever do it when the vehicle is parked. But 48 years driving, 30+ as a HGV driver recon I've covered a few miles without problems, I love technology but don't search for problems that rarely exist.Good luck with that method at 60mph.
Checked with TyrePal staff at the NEC Show & they are no longer selling the Solar 6 as this can be achieved by buying the Solar 4 & 2 extra sensors. We may have a Fun discount code soon for TyrePal so will post a new thread when we hopefully have that. In the meantime for anyone that is a C & MHC member - have a look at their member discounts as they normally have a code.Away at the moment and will miss the show. will look out for your post, thanks
Could a 4 sensor model be used in a tow car along with a 4/6 model in a Moho so that the towed car could be monitored from the cab of the Moho or would they just interfere with each other? If yes then could the 4 sensor receiver be moved to the car when it was being driven, not towed?Checked with TyrePal staff at the NEC Show & they are no longer selling the Solar 6 as this can be achieved by buying the Solar 4 & 2 extra sensors. We may have a Fun discount code soon for TyrePal so will post a new thread when we hopefully have that. In the meantime for anyone that is a C & MHC member - have a look at their member discounts as they normally have a code.
Might be possible as sensors are paired to each monitor but may need the repeater because of distance of tow car from motorhome cab but we aren't experts & have no personal experience of this so suggest calling TyrePal https://www.tyrepal.co.uk/help/ .Could a 4 sensor model be used in a tow car along with a 4/6 model in a Moho so that the towed car could be monitored from the cab of the Moho or would they just interfere with each other? If yes then could the 4 sensor receiver be moved to the car when it was being driven, not towed?
Has anyone fitted one of these monitoring kits , or a tyre pal , which one would they recommend, or are there others which are better,thanks.
MICHELIN TYRE PRESSURE MONITORING FOR MOTORHOMES CARAVANS
I bought a large box of o rings that have sizes smaller than tyre pal ones to about 30mm.. 20 of each size, cost £12..I have the tyrepal
You need to check everytime you remove a sensor that the little rubber o ring is still present otherwise you will get a slow leak.
They fall out easily and are ridiculously expensive for what they are .
Have you got the repeater bit on for the trailer or does it read the trailer just with the head unit? I will be towing a small trailer and looking to have tyrepal fitted to the Moho and trailer and was wondering if I needed the repeater bit.Fitted the Tyrepal one and has worked okay on the trip down to Spain, works on the trailer as well.
I fixed the signal repeater in the back of the van, it works fine but did not try it without it, it may be okay with a small trailer.Have you got the repeater bit on for the trailer or does it read the trailer just with the head unit? I will be towing a small trailer and looking to have tyrepal fitted to the Moho and trailer and was wondering if I needed the repeater bit.
You may need to read the instructions and set it correctly.If it goes bang at 60mph your tyre pal will not forwarn you! I have it in my car. 1 lb pressure loss sets it off. Alowing for temperature change and speed pressure increases it drives me round the bend . I carry a digital pressure gauge and always have my daily walk round check. If you run a tyre at low pressure the walls will be damaged a new one is required .
I thought I’d share the response I gotMight be possible as sensors are paired to each monitor but may need the repeater because of distance of tow car from motorhome cab but we aren't experts & have no personal experience of this so suggest calling TyrePal https://www.tyrepal.co.uk/help/ .
As we understand it the sensors go dormant when stationary to save battery life so if they are compatible a reading may only be possible soon after stopping the vehicle.I thought I read somewhere that the Michelin wireless pressure gauge works on the Tyre Pal sensors - so you can check the pressure while stationary and font have to remove the sensors and use a hold on gauge. Anyone know any more re this??
As I mentioned earlier in the thread, I have Tyrepal on the Frankia and Michelin in my car. I was therefore able to test this. On the car, the sensors do go to sleep to preserve the battery, but they wake up and flash a red light when the tyre pressure measuring device is presented to them.I thought I read somewhere that the Michelin wireless pressure gauge works on the Tyre Pal sensors - so you can check the pressure while stationary and font have to remove the sensors and use a hold on gauge. Anyone know any more re this??
