Meaning of red flashing symbol
Dazz
South Wales Valleys
Ford Chaussonflash02
Newbie
Anybody know what this red flashing symbol means before I dig books out my water is still showing 3/4 full
Looks to me that it is saying your waste tank is full although the water gauges can be very misleading at times, physically check it if you can.
Yes I just checked it and empty it out but still red flashing symbol on control panel
I would suggest you clean the rods within the tank that give you the readings, other than that I can't help more as I am not an electrician.
Good luck.
Norman.
Tucano, is right, the Probes need cleaning (if you can access them) If that don`t work there is an Electrical or probe fault. "grease" could be the issue.?
How do you clean probs do I take the cassette apart lol
Sometimes it needs a bit of push.....Slap the side of the tank! It will work
kev
Fortunately Many Waste tank Access panels are at the top. which usually are hard up against the floor of the `van!. The probes themselves may be inserted into the side (hopefully) trace the wiring and see if they can be removed?.
Dear Doris, i saw the red flashing lights but didnt hear the train coming, can i sue the hearing aid manufacturers?
Yes grey tank I see a purple fuse on the side by this tank I also turned the top of waste tank and a spring like sponge thing I checked and put back in so not sure if I’ve done something wrong as I’m new to this lol
Dazz no one has explained that it is not a symbol for your toilet cassette but for your sink waste tank (grey waste) hope that makes it a little clearer ?
Excuse the pun?
If it’s any consolation my waste tank alert has flashed for months. Cleaned the tank out and there are no rods to be seen anywhere. Even put a camera in to look around.
Unplugged my control panel hoping to reset it but that didn’t work.
Have now resorted to a piece of duct tape over the offending light (y)
some have a series of studs in the side of the tank you find them by following any wiring
Thanks Grasscutter it was the sink waste tank full lol but thanks all for helping ?
