Marker,red tail lights not working on off side near side working fine 2006 fiat 2.8 ducato bessacar e 465
Bracknell
Bessacar E465 2006
Since 2009
Hi all bit of a problem off side marker lights and red tail not working the other side is fine . I have checked the fuses and they are OK is there any where else I can check ie hidden fuses
any help or advice would be much appreciated thanks in advance Dave aka donk
Have you checked the earth on that side?
Bad earth, or maybe blown bulb causing a short circuit.
well if its the same as mine sundance on a fiat chassis it be a broken wire going through the chassis it a single wire going into 2 it just after back wheel
Had the same with the swift sundance .
it wore away on the preformed hole.
COPY this -----
On a slightly related note - I also had a rear light cluster fail - which I eventually traced to wearing through of the insulation of the feed wires where the "Swift" wiring harness joins the "Fiat" wiring harness. This, is just inside the chassis member, where the the unprotected wires emerge through a raw hole in the chassis - not a grommet to be seen. Something to watch out for should anybody else have a similar problem.
ON my Hymer the light clusters and marker lights are all joined in a mess of Lucar spade connectors, spaghetti and holes with no grommets hidden under the moulded rear trim/bumper. It was a mission getting it all working after taking the trim off as it was all oxidised.
Why is most (all?) motorhome wiring so badly done, and not documented?
