LPG regulators
MattR
Beds
Panel van
Years
I have two Gaslow refillable LPG gas bottles with butane regulator fittings. Can I use a butane 28mbar regulator on them or does the regulator have to be higher than 30mbar?
I'm awaiting a delivery of a re-filler kit and new regulator and change over valve but as it has not arrived in time for our overnight trip, I wondered whether a butane regulator would work safely.
I would be very cautions.. and say NO..
not because the output is 2mb lower.. but Propane is at higher pressure in the cylinder than Butane.. , quite probably more than the Butane regulator is rated for.
EDIT
This backs up what I said..
Propane bottles contain considerably greater pressure than butane cylinders. Cylinder regulators designed for use with either propane or butane are not interchangeable because of:-
  • Their different design pressure.
EDIT
Thanks for this. I took your advice and used some old 3kg butane bottles instead. There was enough gas to supply the fridge to keep the bubbly stuff cool and fry some eggs this morning :)
I've no idea how this post came up twice though ...
