Looking for sliding door hinges (for 2013 L3H2 Boxer)
CamperJack
Cheshire
Converting a Van
I'm a Total Newbie!
I ordered some of these. Doors on the left, so went with an advert that mentioned the left. But they are for a left hand drive van!!! (which therefore has the door on the right). Long story short, they are backwards / upside down / don't fit my van!! 😱😱😱
stupid the wizard of oz GIF
There are loads and loads for left hand drive vans (with the door on the right side).
But obviously, with a UK van, I need ones for a right hand drive van (with the door on the left side).
Any ideas where I might find a set?
Does that mean you will not be able to open and "whoosh bang " the door closed if you can't get a set? 😊😉, just asking
It means the van is useless.
"Super Computer" wrongly thinks that the door is open and therefore shows a warning light on the dash (MOT Failure) even though door is securely locked and no amount of pulling will open it without using the key.
Check the micro switch on the sliding door
A small bit of foam pad where the pin makes contact may cure the issue
With the door open press in the pin and see if the warning light goes out
Thanks for the replies.
I shall try this next time im in Cheshire (where the van is, in in Yorkshire at the moment.)
Have you tried www.coastalmotorhomes.co.uk they show hinges in stock , hopefully the correct type you need. (are you sure it is not the rear doors causing the light to remain on , or that the door sensor switch/button/contacts is not the problem ? )
Will try these.
