- Oct 4, 2018
- 160
- 427
- Carthago C-Tourer
- Not so new now
I’m looking for some advice to replace my Motorhome leisure battery as I think it’s on the way out.
I have an Auto Sleepers Winchcombe 2017. I have not looked at the battery yet as it’s under the passenger seat and not easily accessible. However I believe it’s a lead acid battery in the range 75 to 120Ah according to the manual. I appreciate I will need to check the size to fit the available space.
There is a Sergeant EC500 PSU and PX-300 charger. There is also an 80w solar panel which charges both the vehicle and leisure battery as directed by the PSU. The vehicle alternator also charges both batteries.
The manual advises a replacement lead acid battery or will also accept “most” AGM batteries subject to the charging profile. No mention of suitability for Lithium is made.
We don’t do a lot of off grid but like the option for a few days.
My question is what go for, standard lead acid, EFB, AGM or lithium.
I have read the details on KS Energy website regarding the “drop in” capability of their lithium batteries to replace lead acid. However I’ve also read elsewhere that the set up above without a lithium charging profile is not suitable.
If I do decide on lithium what equipment would I need to change.
The charging profile of my current set up is as follows:-
During stage 1 the battery voltage is increased gradually while the current is limited to start the charging process and protect the battery. At stage 2 the voltage rises to 14.4V (Vboost) to deliver the bulk charge to the battery. When the battery is charged, the voltage is decreased at stage 3 to 13.6V (Vflt) to deliver a float charge to maintain the battery in the fully charged state. The charger can be left switched on continuously as required.
The battery charger / power converter can also provide power to the leisure equipment when the mains supply is connected. This module supplies DC to the leisure equipment up to a maximum of 25 Amps (300 Watts), therefore the available power is distributed between the leisure load and the battery, under these conditions the charge indicator will show Red.
I‘d welcome any thoughts. Thanks.
