Before buying a new kitchen swan neck mixer tap in my 3 year old Knaus. Any advice on what might be happening here.
Each morning I’m finding a small pool of water all around the base of the tap on the work surface, with the pump switched off but with residual pressure. If I clear the pressure by running the tap, there is no water next morning.
The problem I have is I can’t see where the leak is coming from.
1) No water under the work surface anywhere, pipes and under the tap all dry.
2) Wrapped kitchen roll around the control knob and it stays dry.
3) Wrapped kitchen roll around the swan neck swivel point and it stays dry.
4) No water dripping from above.
Any suggestions before forking out for a new tap. Was very careful to drain down the water before winter set in and left the tap open in midway position, so very surprised if it’s frost damage.
