- Apr 20, 2022
- 73
- 32
- Adria Supersonic
Hi, can I ask some advice please
I’m on day 4 of a planned 16 day trip in France, at an aire by Vannes. I have no spare parts, but do have some tools.
I’ve discovered that the inspection seal under the grey waste tank is leaking, as well as the large 3” (?) diameter pipe which goes into the bottom of the waste tank.
I have a couple of questions
1. Is it ok just unscrew the inspection seal, check it out and refit, to see if it’s works?
2. Is it okay to remove the other pipe brackets see picture) for inspection and then refit?
3. Do you know where this pipe comes from? It connects at the bottom, so I assume isn’t the feed from taps and shower?
Thanks in advance
Thanks in advance
