Joint Sealing Tape
Clickem
Northumberland
None
7 years
Please does anyone have a possible supplier/source for 20mm adhesive joint tape, similar color/pattern to this:
You could try O'leary or Magnums ... difficult to source though as to what's the right colour unless you can send them a sample or get them to send you samples.
We had the same problem with our Autotrail more so on the walls that got warm with sun heating them up. This was maybe the only remedial work the dealer manage to get right. Replaced by a "D" shaped plastic strip which should have been fitted in the first place. If you replace with the tape it won't last.
