Timbob1961
- Mar 17, 2021
- 30
- 2
- Matrix Supreme 670
Probably be OK, it is Brit built vans that are the worst as the cabling is way undersized.I am about to take delivery of an Adria Matrix 2018..Fiat Ducato based.
I am wondering if this will be an issue that needs solving...
ThanksIt depends on your lifestyle. Some people mostly use the motorhome in the summer, are out walking all day, and sit outside chatting all evening, cooking on the barbecue. Their total electrical demand is very small, and a single 100Ah battery is perfectly adequate, especially if there's 100W of solar panel.
Others use the motorhome in all seasons and weather, use the laptop for work, watch TV for hours, and use a compressor fridge, microwave, coffee machine, hairdryer, and charge electric bikes. Their electrical demand is large, and even 300W of solar won't be enough. They'll want to charge up multiple leisure batteries fast as they drive.
For these people, a simple split charge relay that parallels all the batteries to the alternator won't be enough. Usually the alternator maximum into the batteries is about 30A, and often less. It falls off as the batteries charge. And that's before we mention smart alternators, which are designed to keep the batteries well below full charge.
A good B2B will consistently output 60A, and will keep charging until the leisure batteries are fully charged. It's the only way to charge up 300Ah of battery in finite time.
Will see how I go..It often gets very technical here... and whilst not wrong, most of the suggestions are unnecessary.
Motorhomes just work as they're meant to for the vast majority of users.
Don't look for problems unless they arise.
Mercs for quite a few years, Fiat since 2019 with the Euro 6D engine.Are smart alternators not used in motorhome conversions?
The only problem there is that if you don't have enough charge, the lead acid batteries can be destroyed. Then you need to buy a B2B charger AND a new battery.It often gets very technical here... and whilst not wrong, most of the suggestions are unnecessary.
Votronic, who also make solar controllers, make a B2B but they call it a booster, I think. They also do a combined mains/solar/B2B unit. Victron also do a B2B, called Orion. Schaudt, who make the popular Electroblock 12V charger/distribution box, also do a 'booster'.Sterling was mentioned, any others recommended?
In the video they were not using a B2B. The lithium battery was connected direct to the alternator, much like it would be if using a split charge relay.That Victron test seems to be using the biggest rated B2B they could get, so they could pull all the current and more of their alternator, and also a battery needing some 150Ah of recharging (if they took the 300Ah down to 50%). But the max load they had only got to 75A In the videotoff the standard alternator, suggesting the alternator they were using wasn't that heavy a duty?
Loving all the information in this thread. Apologies in advance for hijacking it a bit.
We're new to motorhoming and just got a 2013 Chausson with a completely shot 100Ah leisure battery and deciding what to do about a replacement. We're pretty sure we'll want to spend most of our time off EHU, likely for a week at a time, so have been thinking a LiFePO4 upgrade would be good but given how expensive they are, we couldn't afford to be replacing the alternator soon after fitting the battery![]()
Could it be possible our unit might have a B2B charger already and what would be the best way to check?
Trying to get my head around the different ways leisure batteries charge. Charging off EHU seems straight forward and I'm guessing this has nothing to do with the engine running. Split chargers have so many different types they really confuse me: Standard, Voltage sensing, Battery isolator, Diode Split. How would I find out which is fitted?
KS Energy, who we're thinking of getting the battery from, sell it as being a direct swap for a Pb battery. Does this sound right or is it marketing nonsense and the charging system of the van wouldn't appreciate it? Is it really as simple as swapping the battery or would I need to change the EHU driven charger and the charging system between the leisure battery and alternator?
