- Oct 16, 2022
- 110
- 296
- Transit Jumbo
Yes but I don't want it on my phone though.If you want a quality one get a Victron they have Bluetooth connection and you can bring all the info up on your phone.
As you are looking a large inverter what batteries do you have?
Im actually about to do another post about that.If you want a quality one get a Victron they have Bluetooth connection and you can bring all the info up on your phone.
You could fit a Victron Cerbo CX with a touch screen to interface with the inverter but that will cost another 400 quid or you can do it for a lot less using a Raspberry Pi.Yes but I don't want it on my phone though.
All these products that put their output via the phone, I don't like that. I really don't like that.
My vehicle is for living in. It does things like store water, generate power and move at a rate of MPH. You wouldnt expect your vehicle to only tell you that you are doing 70mph via your phone would you? What if the phone was flat? Or Lost? Well, I feel the same about power generation, water levels and basically every other level or gauge in the vehicle.
My van will never interface with my phone.
What batteries do you have?Im actually about to do another post about that.
Im bang in the middle of speccing up, ordering and installing the system and just noticed something a little worrying on the battery manual.
Great response. Thanks for that.You could easily have a meter with a display, measuring the amps. Note that the one you linked to, the Ketotek 100A one, will definitely not work on the DC input from the batteries. It measures AC only, so would work on the 240V AC output of the inverter. The 'current transformer' sensor (that coil with a hole in the middle, at the end of a wire) will only pick up AC amps.
You could use a DC meter, which will probably have a 'shunt' that all the amps passes through. It can be wired into either the DC positive or the DC negative wire, it works fine in either position. The best one is the Victron BMV series, such as the BMV700 or BMV712. Both have a separate display, with a data wire between the shunt and the display. The 712 has Bluetooth so it can send data to a smartphone app, or other Victron devices that might find the data useful.
Victron Energy BMV-700 Battery Monitor
Victron multi-function battery monitor with many useful features. Suitable for caravans, motorhomes, campervans, boats, industrial and commercial vehicles.www.12voltplanet.co.uk
Note that if you fit a 3000W inverter, it will draw nearly 300A at full chat, so make sure the shunt can accomodate that. Victron shunts can do 500A, as can some of the cheaper shunts, but quite a few only do 100A or 200A. Shunts are usually used to monitor a battery, but they work fine for measuring amps anywhere - obviously the 'state of charge' calculation should be ignored if it's not directly on a battery terminal.
All I want to know is how many amps are moving across the circuit. I could get out my meter and make a series connection to get the answer. Or I could purchase a very cheap ammeter with a 7 segment LED display so I can always see, at a glance, with no bluetooth connection or wait, where is my phone right now.You could fit a Victron Cerbo CX with a touch screen to interface with the inverter but that will cost another 400 quid or you can do it for a lot less using a Raspberry Pi.
Renogy monitor is seemingly on offer 500amp and £54 Renogy.com UK siteAll I want to know is how many amps are moving across the circuit. I could get out my meter and make a series connection to get the answer. Or I could purchase a very cheap ammeter with a 7 segment LED display so I can always see, at a glance, with no bluetooth connection or wait, where is my phone right now.
I just cant see how any other option other than this would be preferable.
It’s vastly preferable as you get far more information availableAll I want to know is how many amps are moving across the circuit. I could get out my meter and make a series connection to get the answer. Or I could purchase a very cheap ammeter with a 7 segment LED display so I can always see, at a glance, with no bluetooth connection or wait, where is my phone right now.
