No, less than 1% probably would be my guess. I fitted a cheap 1500W pure sine wave* inverter a couple of years ago mostly to run my coffee machine and Mrs DBK's hair dryer. We also use it to recharge the vacuum cleaner, which we do while driving. It's been trouble free and for us it's been a useful extra.... my question is do most owners own an inverter...
Depends what you want to run in your motorhome whether it will be fit for purpose or not..Hi as I’m still learning about MH my question is does most owners own an inverter I’ve seen these on e bay not sure if any good View attachment 350838
Try an electric toothbrush charger or try using GHDs, it fries them.I have never had a pure sine wave inverter in almost 20 years of boats and vans ---and never had the need for one.
Everything seem to work with a standard 1000w inverter.
There are good and cr4p pure sinewave inverters. Good ones are better than grid mains.Same here in my 4x4 camper, modified sinewave inverter has powered everything from Kettles, TV's iphone, Ipads (all at the smae time too) right down to those bluetooth contactless payment boxes, never had an issue with any of them..
and on the other hand I've seen someone at the same camp with a pure sinewave inverter that tried to charge his phone on it and it sent the screen bonkers, yet my modified sinewave one powered it perfectly.
I can use the original charger and my wife can use her GHDsI got a cheap USB charger for my OralB electric toothbrush. Problem solved.
The toothbrush charger was £4 and I don't take the orignal, so it actually saves space and weight.... and I don't need hair irons, so for me it works out much cheaper than a £££ inverter.I can use the original charger and my wife can use her GHDs
