ceejayt
- Aug 12, 2015
- 3,344
- 6,063
- RS Elysian A Class
- Since 2004
You must have the top-mounted ones. Mine are a nightmare at roundabouts to the extent that I considered moving them to where they were designed to be. The LH one on mine is an inverted bottom-mount RH and the RH one the opposite. I've had one apart and the design and markings inside confirmed my suspicions. The giveaway from the outside is the top-mounted blindspot mirror.quite simply, they can actually block the view and some leaning backwards and forwards to make sure nothing is coming at a junction can be necessary
Yes, similar -as you say they can be difficult. However, the forward mounted ones can be equally as obstructive, just at a different point.You must have the top-mounted ones. Mine are a nightmare at roundabouts to the extent that I considered moving them to where they were designed to be. The LH one on mine is an inverted bottom-mount RH and the RH one the opposite. I've had one apart and the design and markings inside confirmed my suspicions. The giveaway from the outside is the top-mounted blindspot mirror.
Please let us know the result.Have asked the for a price and fitting
Will doPlease let us know the result.
Richard.
I've made dummies to test them mounted the other way up and below the side windows and they don't cause the same problem. I have to admit that high up they're out of reach of white van man but in danger of contact with HGVs. Cameras would be better & with more choice of mounting posiotions.Yes, similar -as you say they can be difficult. However, the forward mounted ones can be equally as obstructive, just at a different point.
These seem to be next generation HD. Would want to see them in action before committing.We use them in work. Absolute garbage. Its like watching TV in sd. If you wear reading glasses to read but don't wear glasses otherwise, then you can't focus focus both mirrors. In the night and in poor visibility ie rain etc they're even worse. There's no depth and it makes it very difficult to judge the distance of vehicles coming from behind you. Also the vehicles with HD headlights look like flashing lights and are blurry. Personally i am amazed how they passed legislation. Be very aware approaching/ passing one of these vehicles in poor weather conditions. I and a few of my work mates have refused to drive them. Even those that do drive them don't like them.
Oh and if they fail (and they do) when you're exercising some kind of manoeuvre like being in the outside lane overtaking then you have to try and get back in without having an accident.
Steer clear is my advice.
Several high-end cars have them now. The best ones have such a good dynamic range that when you are driving at night, you can see whole cars and roadside features rather than just a pair of blinding headlights. They can also provide a wide angle with less distortion than a mirror.We use them in work. Absolute garbage. Its like watching TV in sd. If you wear reading glasses to read but don't wear glasses otherwise, then you can't focus focus both mirrors. In the night and in poor visibility ie rain etc they're even worse. There's no depth and it makes it very difficult to judge the distance of vehicles coming from behind you. Also the vehicles with HD headlights look like flashing lights and are blurry. Personally i am amazed how they passed legislation. Be very aware approaching/ passing one of these vehicles in poor weather conditions. I and a few of my work mates have refused to drive them. Even those that do drive them don't like them.
