Abacist
I bought the twin pack which comes with two magnetic sensors to go on the bottom of the two gas bottles, a two level LED gauge to go in your control panel and you download the Mopeka App to see your gas bottle fill levels on your iPhone.
To activate the sensors and gauge for first time use you put the two close together and press the button on each tank sensor unit 5 times in quick succession and the gauge then recognises them and shows them to be empty as you have not yet installed them on the gas bottles. Next download the App and making sure bluetooth is on and load the App. Both sensor units will then appear and you input the size of your gas bottles in Kgs. I took the opportunity to label each sensor so that I know which bottle is being measured - front or back. The gauge has two buttons so the light one is the front bottle and black one the back/rear bottle in the cabinet. I only ever have one bottle turned on at once but this may change now that I can see the levels.
I then had to remove both gas bottles and put them on their sides, clean the round base and then measure to determine the exact centre of the base of each gas bottle. The units are very picky about being in the exact centre of the round base of the gas bottle. You then use a pea sized blob of the enclosed silicone grease to lubricate the sensor. The sensors are magnetic so stick to the bottom of the bottles quite easily. However you need to make sure that there is adequate clearance under the bottle to be sure that the sensor does not either get crushed or tilt away from the bottle. I cut myself a 1/2 inch board to fit the cabinet and then cut out circles 16 cms in diameter to give room for the sensors under the bottles and to lift the gas bottles off the base of the cabinet. The supplied aluminium pegs to attach to the rim of the bottles did not fit my Gasit cylinders so got binned.
My full cylinder shows 90% full on the App which equates to the 80% fill level of a Gasit cylinder and the other one is showing 77% after a long weekends use of the fridge, and intermittently hob, oven and boiler for hot water for showers and dishes. On the gauge next to the control panel there are a series of LED lights to show the levels. The full one lights up all the LED's and the part used one has one LED of the series not lit.
This is going to be very useful, especially in the colder times when the heating, as well as other gas consuming kitchen gadgets are in use.
