Immobiliser issues Fiat Ducato
Pickygame
Fiat Rapido Itineo M
Since 2019, caravans from 2010
Has anyone had issues with immobiliser on a Ducato? My Itineo refuses to start. I have had starting issues before and when recovery vehicles or garages get the vehicle it starts ok. I get fuel but no firing. Full battery power. Once its running it runs fine.
I assume it is a diesel. I only have experience of older diesels but found difficulty starting can be caused by poor compression, defective glow plugs, wrong fuel. If you have added some petrol by mistake it will run but after stopping unlikely to start.
A compression check is best done by a garage, more complicated than a petrol engine.
Glow plugs are a service item and do wear with age.
Wrong fuel, if tank is low top up with diesel or drain and refill.
Good luck🤔🤔😀
A Diesel only needs 3 things fuel, air and compression. As you say it runs ok once started I would cross off compression. You say you have fuel where? No glow plug power would make it hard to start but not impossible.
I'm suspecting a lack of fuel. Do you have a primer for the fuel system either a pump in the tank/fuel line or a manual one under the bonnet? If manual try a few pumps before trying to start, pump should get hard. Let us know how you get on.
If the engine is turning over on the starter it won't be the imobiliser.
What year is it?
I opened the fuel filter bleed screw and with ignition on got fuel.
It's unlikely to be the immobiliser then. The CODE immobiliser was fairly unreliable and when have sent out hundreds of help sheets telling people how to remove the immobiliser that Fiat said could be removed.
You'll need expert diesel advice I suspect. One thought though? do you get clouds of white smoke out of the exhaust when your turning the engine over?
No white smoke.
Is it turning over at its “normal” speed when your cranking it or slowly like a flat battery? They do need a certain speed to start to get the fuel to explode through compression.
Turns over full speed. Battery is trickle charged through solar panel
If it runs well once you get it started it sounds like a glow plug fault to me, although that wouldn't account for why it starts O.K. for the recovery chap.
Would have thought you would get glow plug warning on your dash if it them?😊
May be worth checking for any fault codes stored via the OBD.
Geoff
I had a immobiliser problem.on a 2011 Ducato van , sort of , wouldn't turn off so I had to stall it then it turned over but wouldn't fire
Breakdown came out , cleared the codes and it started so I drove it 200 miles home to the garage , he took the NS headlight out and found corroded wires
Changed them, no problems since
I took this picture of their scanner when he wasn't looking🤫
I think i have sorted it. On following this i noticed i have a Chip Express tuner fitted. (last owner probably). Took it off and fitted the blanking plug and it starts fine. I think the chip has got water ingress or something.
Result , I knew it was worth taking that picture
