ICE / Satnav upgrade
Bottesford, Scunthorpe, UK
Autotrail Cheyenne
Newbie
I have just fitted a double DIN radio satnav media player to the dash, it's replaced a single DIN Pioneer jobby plus a windscreen mounted satnav (which had to removed every time we wanted to close the blinds) that also had reversing camera feed, all wires that were needed were there, I only had to site the satnav aerial, no moving parts
Looks good! What make/model is it……?:unsure:
Vary much like this one but I have had it 18 months was going to fit in a car but didnt do it before car went so putting it to good use now
Hope not to put a damper on your install, but I had one of those.
Two major problems: the touch controls for volume - pain in the whatnot when driving.
and also, there is no heat sink on the amplifier chip, so it overheats very quickly in hot weather and reboots (if you are lucky), or just locks up requiring the supply to be cut off to reboot.
Can be fixed with stick-on heat sinks and small fan if you travel a lot in hot areas. Lots of youtube vids available.
Ended up changing it for one with a nice big knob and proper cooling.
Good luck with yours
