Hymer drop down bed lock. One side only
Washington
Hymer B 584DL
17 years + 35 tugging
Anyone had a hymer bed that locks in the high, closed position on the near side only and hangs a bit loose on the off side. Hymer B 584DL, drop down bed with extensions.
Or do they only lock on one side? In which case the off side is hanging a couple of inches too low.
On mine it doesn’t lock as it’s an Exsis.
One side had dropped though as the strut was duff.
Sorted:
Pull back the bed side curtain and the wedge shaped block that captures the bed lock when the bed is stowed has two allen screws. Loosen these and there are 4 adjustment holes that allow the bed to lock higher or lower. Lower makes it easier to shut but may not line up the bed with side cupboards. So you have choices. Not as good as the old centre strap that allowed you to close to any height that your bedding required.
